basshead2k's avatar
Jun 15, 2021
ReadyCLOUD app not backing up iPhone/iPad
There’s two closed existing threads on this topic from 2017-2018. Issue started about a couple of weeks ago - possibly caused by iPhone/iPad iOS update (14.6) as the ReadyCLOUD app has not been update...
  • basshead2k's avatar
    basshead2k
    Aug 13, 2021
    Sandshark wrote:
    If you updated within the same main version (6.5.x to 6.5.x, for example), you can downgrade just like you upgrade from a local file.  If you went to the next main version (6.4.x to 6.5.x), then downgrading is not recommended.  With only a few exceptions (but, unfortunately, I don't know all of them), you can safely downgrade and then do a factory default.
    downgraded firmware from 6.10.5hotfix to 6.10.4 fixed the problem.  6.10.5 still wouldn't work
ProSupport for Business
