StehpenT
Mar 05, 2019Star
ReadyCloud Desktop Client - Network Error ReadyCloud Server is unavailable
Hello,
ReadyNAS Desktop Client shows "Network Error ReadyCloud Server is unavailable", but the ReadyCloud is working ok. Could you please help checking on this. Thanks.
Stephen
- Mar 05, 2019
Hi StehpenT
You need to upgrade your App. This is due to ReadyCloud raising security level for the servers. The old versions are being restricted access.
Kindly use this
Windows: http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe
MacOS: http://readycloud.netgear.com/client/install/ReadyCLOUD.pkg
Regards
Marc_V
Mar 05, 2019NETGEAR Employee Retired
Hi StehpenT
Kindly use this
Regards
StehpenT
Mar 05, 2019Star
Hello Marc_V
Install ReadyCloud client v1.17 resolved the issue.
Is there a way to get notificed if there is any change on ReadyCloud? Please kindly advise. Thank you.
Stephen
- NanodotMar 05, 2019Initiate
Failed all day, google brought me here... Thanks!
- ryks82Mar 07, 2019Aspirant
Good if you not block the update funktion in the software next timme.. Tryed but same error messege and nothing that says..
- GMAC67Mar 07, 2019Aspirant
Careful, mods don't like it when you complain.
What a joke.
