StehpenT
Mar 05, 2019Star
ReadyCloud Desktop Client - Network Error ReadyCloud Server is unavailable
Hello,
ReadyNAS Desktop Client shows "Network Error ReadyCloud Server is unavailable", but the ReadyCloud is working ok. Could you please help checking on this. Thanks.
Stephen
- Mar 05, 2019
Hi StehpenT
You need to upgrade your App. This is due to ReadyCloud raising security level for the servers. The old versions are being restricted access.
Kindly use this
Windows: http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe
MacOS: http://readycloud.netgear.com/client/install/ReadyCLOUD.pkg
Regards
