DonQ
Aug 12, 2016Aspirant
ReadyCloud says its offline - access ok via explorer
I received the NAS RN204 yesterday, Set it up, connected, trasnferred initial lot of data. This morning went to work on it and after logging on to ReadyCloud via browser a message came up saying...
- Aug 14, 2016
DonQ wrote:
Solved. I still cannot access straight away via the browser when I start up. However when I run RAIDar it finds the RN204 and everything is fine from there. It seems that each time I have to run RAIDar first. Cheers StephenThat suggests that your NAS IP address might be changing when you start up the NAS. You can try reserving the IP address in your router.
DonQ
Aug 14, 2016Aspirant
- StephenBAug 14, 2016Guru - Experienced User
