PaulLin
Mar 22, 2023Aspirant
Readycloud services termination
Hi, With regarding to the readycloud service termination , How would this impact to the user setup at readycloud ? Currently I have user setup under cloud user (not local user). Thanks in ad...
PaulLin
thanks Stephen, Do you mean I have to relocate all the exisitng homeholder conent since all the cloud user home folder will be removed?
Thank in advance for yoru reply
Mar 22, 2023Guru - Experienced User
I don't think the current cloud user folders will actually be removed from the NAS.
But your users won't be able to access the NAS using their cloud credentials. So the contents will have to be moved to their new user accounts.
This is a bit tricky to do, due in part to the ACL that is applied to the home folders. Another complication is that the home folder is normally created the first time a user connects to the NAS using SMB.
One option is to have each user copy their folder to their PC before you shift to the local user accounts, and have them upload it to the newly created folders. Optionally they can remove any files they no longer care about.
You can also do this for each user when you create their new account - copying their current folder to a PC (or a temporary share) using your admin credentials. Then you can log in from Windows using the new account credentials, and upload the folder contents.
A PITA either way.
