NZScott1337
Jun 28, 2020Aspirant
ReadyNAS - 2 drives working - 1 drive not working - no errors
Hi Team, I have a ReadyNAS Ultra 4 Plus. I have 3 hard drives in it. - 4TB Seagate - 4TB Seagate - 3TB WD Green Until a few days ago, all shares were accessible. The problem: Both 4T...
Jun 29, 2020Guru - Experienced User
What firmware are you running?
What RAID mode are you using?
I suggest downloading the full log zip file, as there could be some clues in there.
- SandsharkJun 29, 2020Sensei
The green drive will not display SMART data when it is spun down. Try to access some data on it before you try to read SMART. The SMART data in the log file .zip may also be helpful. It should also re-read SMART on boot, but a reboot at this point may cause more problems.
