Vamcy
Mar 03, 2018Aspirant
ReadyNas 102 - Stuck at booting with Flashing blue Light
Hi, I need some help with my ReadyNAS 102 (RN10200) as it is struck on Status : System Starting up and not booting at all after firmware update (6.9.2). Steps carried out: 1. Tried restarting usin...
Vamcy
Mar 07, 2018Aspirant
Hi mdgm-ntgr,
Thank you very much for the reply.
Tried doing Volume read only no luck with that too.
Just in case if anyone else is in my situation, its worth checking if both the disks are healthy even though it gave me 2 green ticks on RAIDar.
In my case what I did:
1.Had to pay for the support otherwise I had no idea if it was a drive failure. (would be good to know if there is a way to find out without having to involve paid support, but in my case i took this step)
2.Found out which one of my drive gave up from the helpful support team and have to boot with the good one.
3.Took a backup of the data(do not reformat the drive before you verify the data, to avoid any dissapointment)
4.Got 2 new drives installed with more storage.
5.Transfer the data from backup.
Hope it comes handy for others
Cheers
Vamcy
mdgm-ntgr
Mar 07, 2018NETGEAR Employee Retired
In 6.9.3 (the latest firmware, released this week) the NAS should hopefully boot into safe mode where you could check the SMART stats to see if there's a bad disk.
I'd recommend updating to that (though hopefully your system won't run into a state where it fails to boot anytime soon).
- StephenBMar 07, 2018Guru - Experienced User
Also, if you haven't scheduled the volume maitenance functions (via the volume settings wheel), you should do that. I run each of them once every three months (on a staggered schedule).
