mrd
Jul 03, 2013Aspirant
ReadyNAS 102 Bug list.
- Disk usage is reported incorrectly by GUI
- Disk usage graph is not reported correctly and does not match incorrecly or correclty reported actual usage number.
- Alert email configuration can not be changed after installation. Not sure where it gets the address or mail type from??? Does not work due to incorrect information. No way to "Save" changes.
- Multiple backups show "in progress". Only one backup should ever be "in progress" at a time.
- NFS performance was terrible until I manually added "async" to the nfs export, but new shares are performing well now without the addtion. Not sure if reboots solved the problem?
- Edits to backup source or destination causes GUI to show plain text password and corrupted field entries.
- Backup schedule does not work. All backups are run starting at midnight.
- mdgm-ntgrNETGEAR Employee RetiredTranscoding is only needed if you are streaming video to a device that can't play it back natively.
As for mrd's issue I will respond in http://www.readynas.com/forum/viewtopic.php?f=31&t=77323 - mrdAspirantSince I started this thread, I wanted to make sure anyone with the same recent problems I have dealth with can find the answer here:
SOLVED!
Rsync:
After a factory default and reinstrall with the latest RN102 firmware availabel on the forums, I created all new shares in the exact same way as the first time and now was able to enable rsync password for all shares.
NFS:
It turns out that there was a firware bug with the Netgear Prosafe switch that this NAS is connected to. Netgear JGS524PE
A firmware upgrade resolved teh NFS issues.
I appreciate all of the help from the forum, which is what led me in teh direction of a possible network problem. - mrdAspirantWell... its not quite solved...
Take a look at the most recent post where I am still having trouble with multiple shares and NFS.
