zolvin
Oct 13, 2015Aspirant
readynas 102 cannot access local and remote (via vpn) admin
I've took from my work readynas 102 with 2 tb disks inside. Reseted to factory, upgraded to 6.4.0, and can't access admin page via 192.168.1.65 neither through vpn 5.16.223.102 what am i doing wron...
BrianL2
Oct 13, 2015NETGEAR Employee Retired
Hi zolvin,
Welcome to the community!
We need to gather more details about your device and network setup. I have listed my questions below.
1. If you will open the RAIDar utility for MAC, does it detect your RN102?
2. Does your computer and RN102 on the same IP segment?
3. Do you still have access to the files?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
zolvin
hi
1. i tiried raidar, but when nas ws already installed via readycloud, so raidar foun nothing
2. for sure - nas 192.168.1.65, mac - 192.168.1.66 nas via lan, mac via wifi
3. via readycloud i have access, but not via afp: or smb:
- BrianL2Oct 14, 2015NETGEAR Employee Retired
Hi zolvin,
Thank you for the information that you have provided. Could you confirm if you have done this locally? I've sent you a PM for further instructions.
Kind regards,
BrianL
NETGEAR Community Team- zolvinOct 14, 2015Aspirant
Yes. I was making it loccaly. NAS on the same router via LAN as i'm connected via Wi-Fi to the same router.
Brian
Thanks a lot for the help. But looks like i'va found what is the problem.
It's very local problem to Russia and Moscow and IP - MGTS GPON via Sercomm RV6688BCM with local firmware for this IP to work.
Looks like i don't have full access to router and some of the ports between LAN and Wi-Fi closed. Cause when I made same thing on Asus RT AC66U evrything worked perfectly. Even ps3 found DLNA server - NAS.
But! not with this one. So a I read forums, and found that this is the problem of IP and the only way I could done this make subnetwork, with other router.
Andrey
