Jelutho
Oct 08, 2019Aspirant
ReadyNAS 102 firewall disabled after firmware update
Hi all, after an update of ReadyNAS 102 firmware to V6.10.1 (from 6.9.2) I noticed my firewall button was red / disabled in the Ready cloud. I have seen no "firewall turn on" check box prior to updat...
- Oct 09, 2019
Jelutho wrote:As said in a previous reply the Firewall is discontinued after the udate.
"Firewall" is not the same as "Antivirus". A firewall controls connections to the NAS (blocking access); AntiVirus looks for infected files. Your repeated use of the wrong term is what created confusion here.
Your screenshot definitely shows that AntiVirus is disabled. So the thread can be closed.
Oct 08, 2019Guru - Experienced User
Look on the cloud page of the NAS web ui ( https://nas-ip-address/admin ). First make sure the ReadyCloud service is enabled. Then look for two green checkmarks at the top.
Let us know if you see that.
