Jelutho
Oct 08, 2019Aspirant
ReadyNAS 102 firewall disabled after firmware update
Hi all, after an update of ReadyNAS 102 firmware to V6.10.1 (from 6.9.2) I noticed my firewall button was red / disabled in the Ready cloud. I have seen no "firewall turn on" check box prior to updat...
- Oct 09, 2019
Jelutho wrote:As said in a previous reply the Firewall is discontinued after the udate.
"Firewall" is not the same as "Antivirus". A firewall controls connections to the NAS (blocking access); AntiVirus looks for infected files. Your repeated use of the wrong term is what created confusion here.
Your screenshot definitely shows that AntiVirus is disabled. So the thread can be closed.
Jelutho
Hi, thanks for the reply. The readycloud is switched on and the internet and services are flagged green.
JohnCM_S
Oct 08, 2019NETGEAR Employee Retired
Hi Jelutho,
Are you referring to the built-in Antivirus service on the ReadyNAS? If you are, that service was removed on the RN100 series since the 6.10.0 update. This is due to the minimum requirement of the current AV is exceeding the physical RAM of those units. You may check this link for more information.
