M8TJT
Jan 07, 2016Aspirant
ReadyNas 10200 No Disk Temperature for WD Reds
I have just bought a ReadyNas 10200 running S/W 6.4.1 (the latest at the time of writing), popoulated it with a couple of WD RED WD20EFRX 2TB disks and attached to my network with the main computer r...
Jan 07, 2016Guru - Experienced User
I see the same thing with my WD30EFRX in my RN102, and also with the WD60EFRX in my RN202. Also, sometimes the temp on the system performance page shows up as blank.
This is not new behavior, and it would be nice if it were fixed.
M8TJT
Thanks for the heads up on thgat Stephen. I am not over excited about it, but I am a believer thgat if something is there, it should work.
Is it all drives, or just the WD ones that exhibit this 'feature'?
Trev
- StephenBJan 07, 2016Guru - Experienced User
Trev
I only have WD Reds in my OS6 NAS, so I don't know about other drives.
I believe that this is a glitch in the SMART stats query.
