Maneyact
Mar 15, 2018Aspirant
ReadyNAS 10200 not seen by Raidar
Hi, We have a ReadyNAS102 which I can no longer access. It is not recognised by RAIDar and the indicator lights for the drives do not illuminate. I have very limited info I can supply like fi...
Maneyact
Mar 16, 2018Aspirant
Hi, Yes I have retried rebooting. Have left off power overnight as well and rebooted the next day. No joy there.
I can access the Boot menu. Are you going to suggest an OS Reinstall?
mdgm-ntgr
Mar 16, 2018NETGEAR Employee Retired
Well I’d probably try booting to volume read-only mode as the first step.
- ManeyactMar 16, 2018Aspirant
It still doesn't appear to be doing anything. When I try booting in Read Only, I can access the correct settings, Power light and Disk 1, I press the reset button again and the power light flickers for a little while (about 5 seconds) and stops. I then just get the same as normal, Power and Act lighs constant. No Drive lights.If I go into RAIDar again, still fails to see the whole NAS unit.
The Led on the network socked does flash and the computer does find it.
- StephenBMar 16, 2018Guru - Experienced User
Maneyact wrote:
The Led on the network socket does flash and the computer does find it.
Can you explain this a bit more? Are you saying that you can ping the NAS from the PC?
Can you try powering down the NAS and removing the drives (labeling then by slot number). Then power up again, and see if RAIDar finds the NAS (reporting a "no disks" status). That will give some information on whether the NAS chassis is ok (or not).
- mdgm-ntgrMar 16, 2018NETGEAR Employee Retired
You could have a bad disk. It may be worth powering down, removing your disks (label order), connecting them up to a PC and testing them using SeaTools for SeaGate disks or WD Data LifeGuard Diagnostics for WD disks.
You can do troubleshooting at your own pace. The community is here for your benefit and we hope you find it useful.
