Shri-Ganesh
Nov 01, 2017Tutor
ReadyNAS 104 - Max DIsk Capacity
Hi, I am currently runnin latest version of ReadyNAS OS (v6.9.0) on ReadyNAS 104 and it's running on X-Raid with 4x4 TB HDDs. I want to know what is the maximum capacity supported by ReadyNAS ...
Shri-Ganesh
Nov 01, 2017Tutor
Thanks for the inputs. So is it safe to say that instead of using 4x8TB on my current NAS, I should upgrade my NAS too for flawless functioning?
Nov 01, 2017Guru - Experienced User
That's what I would do.
Later on you could then re-purpose the RN104 as a backup.
