BWIQ-RNO
Oct 20, 2017Follower
ReadyNas 104 - NAS to NAS Sync
Hi there, I am curious if the ReadyNas 100 series is capable of performing NAS to NAS sync. The NAS to NAS replication / backup feature doesn't quite look like it will do what we need it to. Our goal is replicate data between two ReadyNAS 104 appliances that will host the same data with both sides being active and changes to either side being replicated to the other. We're dealing with about 5TB worth of data so storing that on all pertinent workstations with the sync software isn't really feasible.
Thanks!
1 Reply
You could try resilio sync, but you might run into some situations where a change doesn't take (or operates to undo a modification).
One variation is to run sync on one PC on each end, with the NAS data volume mapped to a PC drive letter.
