blanzon
Apr 27, 2019Tutor
ReadyNAS 104 Email Alert not working
I have tried every possible combination, including the new auto login via the Gmail login button, but I simply can't get the alerts to send. Help please.
Notes:
1. When I use the Google login...
Retired_Member
Apr 28, 2019Hi blanzon, you wrote "my user, pw, smtp.gmail.com". Just skip the "smtp" and go with "my user, pw, gmail.com" only.
Good luck with fixing and kind regards
- StephenBApr 28, 2019Guru - Experienced User
My settings (which do work) has this in the main section
X.X@gmail.com pw gmail.com
Advanced then has
smtp.gmail.com 465 X.X@gmail.com Use TLS is checked.
I'm using the main gmail account setup (not an application password).
- blanzonApr 30, 2019Tutor
Thanks StephenB!
I tried but still didn't work. However, updated the security setting on my gmail and it has now worked. Seems previously Gmail was blocking access. Thanks!
