blanzon
Apr 27, 2019Tutor
ReadyNAS 104 Email Alert not working
I have tried every possible combination, including the new auto login via the Gmail login button, but I simply can't get the alerts to send. Help please.
Notes:
1. When I use the Google login...
Retired_Member
Apr 28, 2019Hi blanzon, you wrote "my user, pw, smtp.gmail.com". Just skip the "smtp" and go with "my user, pw, gmail.com" only.
Good luck with fixing and kind regards
Apr 28, 2019Guru - Experienced User
My settings (which do work) has this in the main section
X.X@gmail.com pw gmail.com
Advanced then has
smtp.gmail.com 465 X.X@gmail.com Use TLS is checked.
I'm using the main gmail account setup (not an application password).
- blanzonApr 30, 2019Tutor
Thanks StephenB!
I tried but still didn't work. However, updated the security setting on my gmail and it has now worked. Seems previously Gmail was blocking access. Thanks!
