editnev
Jun 04, 2018Follower
Readynas 104 HDD
Hi all,
Ive got a readynas 104 with 3, 4tb HDDs.. but my available storage is only 8tb .. i have a feeling its beause of raid 5... any way to change this to access the remaining 4tb?
Tha...
Jun 04, 2018Guru - Experienced User
The capacity rule for XRAID is "sum the disks and subtract the largest", which yields 9 TB (or ~8.2 TiB). The NAS actually displays TiB (1024*1024*1024*1024 bytes = 1 TiB).
This drop in capacity is needed in order to preserve your data if a disk fails, and it is also required if you want to expand the array in the future. The "missing" space holds the parity blocks that allow the NAS to regenerate the contents of any failed or missing disk from the remaining three.
To change the RAID mode, you need to change to flexraid, destroy the existing volume, and then create new volume(s) using RAID-0 or JBOD. This is destructive, so you'd need to restore all the data. After the change, a failed disk drive will result in data loss, so you'd need to restore the data from a backup. Also, you won't be able to expand storage without restoring data from backup.
There are two options if you decide to proceed. The one I recommend is to create four volume (one for each disk), and to spread your shares across them. That is a bit more work to maintain, but when a disk fails you will only lose the data on that disk. The other option is to create one volume that spans all four drives. That is somewhat more convenient, but when any disk fails you will lose all the data on the NAS.
