Emil889
May 03, 2015Tutor
Readynas 104 lock up after upgrading to 6.2.4
Hi! I have tried to search around the forums to see if there is any known issue with the 6.2.4 release that causes lockups/hangups on the RN 104. The only thing i found was that older versions li...
Emil889
May 04, 2015Tutor
vandermerwe wrote: Can you check the smart stats on your disks.
Have you received any messages about disk errors?
Do you have any apps installed?
There are no newer beta releases, however there is early access to 6.3.4. I would consider that this is still effectively beta for all units except the 200 units.
Problems like this are often unrelated to the firmware update, so one should still be systematic in excluding other causes before reaching a conclusion that the firmware is the problem.
Has the unit only hung once or is it a recurring problem?
Sorry for a stupid question, but where do i check the SMART-status of the disks?
The only status-like things i can find is this:
