Emil889
May 03, 2015Tutor
Readynas 104 lock up after upgrading to 6.2.4
Hi! I have tried to search around the forums to see if there is any known issue with the 6.2.4 release that causes lockups/hangups on the RN 104. The only thing i found was that older versions li...
Nhellie
May 04, 2015Virtuoso
You can get a more detailed one on Volumes tab, hover the mouse on the disk and it should give you some more info. Check for Temp, ATA errors and Sectors.
