saf1
Mar 23, 2016Aspirant
ReadyNAS 104 Missing directory
Is there any specific log to check for a missing folder on my Ready NAS 104? I don't recall when but this morning I went to look for a folder and no longer see it. I've tried shutting down the NAS ...
saf1
I see the last successful mount on:
Mar 22 14:40:26 shepherd rpc.mountd[4232]: authenticated mount request from 192.168.1.240:879 for /data/Fitness (/data/Fitness)
Then on the 23rd it isn't exported:
refused unmount request from 192.168.1.240 for /data/Fitness (/): not exported
Odd. About the only change would be that I installed istat then removed it but wouldn't think that would be a issue. Although after I uninstalled I see it still left a folder behind.
- mdgm-ntgrMar 23, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig) and also mention the path to the missing folder in your email?
- saf1Mar 24, 2016Aspirant
I didn't reply last night but I did send / upload the log files per the request.
Thanks.
- saf1Mar 26, 2016Aspirant
Any luck with the log files?
I managed to login to the ReadyNAS 104 this morning and didn't see anything obvious. Figured I'd see if you guys/gals had any luck with the actual log files.
Thanks.
-scottf
