hmuessig
Apr 18, 2013Luminary
ReadyNAS 104 Ports Question
So the 104 has 2 USB 3.0 ports, 1 USB 2.0 port, and an eSATA port. But virtually NO documentation as to how these ports can be used . . . The 104 box clearly states that the eSATA port can be u...
Apr 18, 2013Guru - Experienced User
This is printed on the box? Or are you finding this somewhere else?
hmuessig wrote: The 104 box clearly states that the eSATA port can be used with the EDA500 expansion chasis.
My understanding is that it cannot be used with the EDA500.
EDIT: viewtopic.php?f=20&t=70581&p=391956#p391955 shows where this is on the RN104 box. Hopefully Netgear can clarify this.
