Spanfan's avatar
Spanfan
Tutor
Jun 03, 2020
ReadyNAS 104 problems
I have two problems. I'm running the latest firmware and don't see the option for Antivirus that used to be there. Has it been removed ir if not how do I turn it on?
Secondly, for some reason when i access the NAS from my PC the screen is the normal size but everything on it  is very small and barely readable see attached. How do I return it to normal size?
  • StephenB's avatar
    Spanfan wrote:
    I have two problems. I'm running the latest firmware and don't see the option for Antivirus that used to be there. Has it been removed or if not how do I turn it on?
    It was removed a while ago.  The RN104 no longer has enough memory to run it.
    Looks like a browser issue to me.  Check the zoom setting when you are browsing the admin page.  Note that entering ctrl+ will increase the zoom level in most browsers (and cntl- will decrease it).
    • Spanfan's avatar
      Spanfan
      Tutor
      Thanks, it was the browser. That's sorted. Shae about teh antivirus, that's why I've some of my NAS files have been infected with kupidon ransomware even though the PC is clear.
      Is there any antivirus that will protect the NAS as Malwarebytes doesn't?
      • Sandshark's avatar
        Sandshark
        Sensei
        I am unaware of any virus that can actually infect the NAS.  So some PC with access to the files must be infecting them.  Malware Bytes should be taking care of that.
        Some PC virus checkers can be configured to check a mounted share, but that can be very slow.  In fact, on some, you have to expressly tell it not to if that's your desire.
ProSupport for Business
