Kweegly
Nov 30, 2018Aspirant
Readynas 104 Re-sync
Hi Everyone,
I have ReadyNAS 104 which was running 4x4TB drives using X-Raid, drive1 was returning a lot of errors and the nas stopped responding all together. I have purchased a replacement 4t...
Kweegly
I removed the disk and rebooted the NAS, the NAS then displayed "Data degraded" on the LCD screen which was new. At this point I inserted the new disk which started syncing.
- SandsharkDec 01, 2018Sensei
I expect all will come out fine. What you saw can happen when you replace a drive (especially drive 1) with the unit off and that drive is pre-foprmatted. The unit gets confused in the boot process. The proper way (as you did the second time) is to hot-insert the replacement drive.
