nashoot
Dec 20, 2018Aspirant
ReadyNas 104 Volume inactive or dead
Hi all
My readynas showed a disk failure the other day. So i bougt a new disk and did a hot swap on the defective disk.
Now my volume says Inactive or Dead.
What can i do? Is there ...
JohnCM_S
Dec 20, 2018NETGEAR Employee Retired
lHi nashoot,
Welcome to the Community!
Do you have backup of your data?
Please download the logs and then provide it to us so we can check what caused the issue. You can upload it to a file sharing site and then PM me the download link.
- nashootDec 21, 2018Aspirant
Hi John
This was my backup, so unfortunately no.
I have attached the logs. Hope this helps
<redacted link>
- JohnCM_SDec 21, 2018NETGEAR Employee Retired
Hi nashoot,
Based on the logs, another disk has failed while the new disk 3 is syncing which caused the volume to be inactive. I have PMed the serial number of the other disk that failed.
It will be best to contact support for data recovery. (https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service)
- SandsharkDec 22, 2018Sensei
If it "is your backup", meaning other copies of the data exist, then there is, of course, no need to pay for data recovery. Just replace the other bad drive, do a facory default, and refresh the backups. If you mean "it is my archive", so not all data exists elsewhere, then some kind of recovery is going to be necessary if that data is important.
