PSXman's avatar
PSXman
ReadyNas 104
ReadyNas 104
I have an issue when I went to install Zerotier this time on my latest NAS I accidently dis apt-get update & upgrade now I have no access to the readynas admin web interface.
I have tried the restore firmware from usb and it completes but I cant get it to go to the admin web page is there anyway to restore the factory firmware ?
Or anything  I can do in SSH to get this back or is there anyway to backup my other 104 firmware and restore on the broken one ?
Thanks for looking
  • Can you access your files via SMB?  If you can, then make sure your backup is up to date before you try anything else.  You can also do it via SSH if you need to.  You might be able to do it via backup jobs from your other NAS.  If you can back up your data, then I recommend you do so and just factory default the NAS and start over.
    I don't know why you went to USB recovery when an OS re-install is what you should have tried, though I'm not sure it would have worked any better.  I think that a USB recovery also always does an OS re-install, but you can still see if that fixes anything.
    This kind of issue is usually the result of a corrupted configuration file, often one changed/added by an app (so a recovery doesn't correct it).  In your case, it may be something else associated with an app -- that it's now trying to run an updated app or dependency for one that's incompatible with the OS or the main app version.  If that's it, then you can probably mount the volume and backup files from recovery mode (StephenB is a better one to guide you through that than I).
    Cloning the OS partition of another unit isn't going to work.  There's a lot of unit-specific data there.
    If you can't back up your data using any method and then factory default, I know of one thing that might work, but it's very risky.  You'll lose the NAS configuration, but be able to recover the volume data as long as it was a RAID1 or better.  Let's see if an OS re-install works or if anyone else has a better suggestion before you try what I'm thinking of.  But here is the basic plan:
    1. Export the current volume via SSH.
    2. Remove all drives.
    3. Insert a scratch drive and create a volume that's not called data and with no shares.
    4. Power down and add 3 of the 4 drives from the original volume.
    5. On power-up, the NAS will import the old volume as a second one, though it will be degraded since it's missing one drive.  But the OS on the new scratch drive will be what's active (and will also be duplicated to the other three drives).
    6. Now you will have access to the files.  Anything in user shares will have to be dealt with via SSH, but the rest can be copied via SMB and/or backup jobs to your backup.
    7. After file backup, the best bet is a factory default with all the original drives.  There is a way to avoid that, but it carries risk that may not be immediately apparent.  I don't think Netgear created the Export function for this use, and I don't know if I've figured out all the intricacies of it (since it's entirely undocumented).  I've done a lot of experimenting with Export/Import, and learned a lot.  I even did exactly what I'm suggesting here.  But I also ran into some issues for which I do not know the cause, including loss of a volume.  But I was working with a "sandbox" NAS and didn't care about the data on it.
    If it comes down to implementing this plan, I can give you more details.
    • PSXman's avatar
      PSXman
      Its not an issue i have just put 1 drive in it can replace that drive with another no data to loose only thing i cant see is the web admin page to do the firmware update or reload os any ideas i thought doing it from usb would be the best bet but it keeps the name etc so was going to try reset but wanted to make sure i had replaced the firmware so i can re do zerotier which for some reason wouldn't work this time coped the conf files from the working nas same model.
    • PSXman's avatar
      PSXman
      I've replaced the drive and factory reset and its back to normal but am having issues with the install of zerotier even though I've done it before on another 104 I own and it works fine
      • StephenB's avatar
        Have you looked into the error on the https method being missing?
ProSupport for Business
