aanthony1
Dec 03, 2017Aspirant
READYNAS 10400 - Error code of Volume Data Raid Level 5, Not Redudant (3.7TB used (69%) of 5.7TB)
Need help to fix the following Error. Any advise would be greatly appreciated. Do I just need to replace with a new HD of 2TB???? Thanks aanthony1 Sun Dec 3 2017 10:20:15 System: ...
- Dec 03, 2017
Disk 4 has failed, so you do need to replace it. It'd be best to back up the data on the NAS before you do that - if another disk has issues, you could end up losing all your data.
I don't recommend desktop drives for your NAS. If you like seagate, replace the disk with a Seagate Ironwolf model. You could also consider the Western Digital "Red" drives. Both lines are designed for NAS/RAID arrays, and users here are generally happy with them.
On the other hand, a lot of users have issues with Seagate "DM" drives in their NAS.
In any event, the process is simply to remove disk 4 (with the NAS running), and hot-insert the replacement disk.
If you don't have email alerts configured on the NAS, I recommend setting them up. When you see disk errors, you don't want to delay dealing with them (and I think disk 4 has been failing for a while now).
System: The host name contains illegal characters. This may cause undefined behavior when using some network services. Please change the host name using only valid characters (A-Z, a-z, 0-9, -).
You should fix this too. Note that the underscore character isn't legal in host name, that is a common cause of this particular problem.
Dec 03, 2017Guru - Experienced User
System: The host name contains illegal characters. This may cause undefined behavior when using some network services. Please change the host name using only valid characters (A-Z, a-z, 0-9, -). |
- aanthony1Dec 03, 2017Aspirant
Thanks You
Stephen B
I currently have a 4 X 2TB in each slot, can I replace Disk 4 with a WD [WD30EFRX] 3TB RED Internal 3.5" Desktop SATA Drive and then Disk 3 slot after, with another WD [WD30EFRX] 3TB RED Internal 3.5" Desktop SATA Drive.
I believe they have to be the same Volume in each drive. (3 & 4)
Only an extra $20 for the 3TB. Will buy 2 X WD [WD30EFRX] 3TB RED Internal 3.5" Desktop SATA Drive.
Will then replace the others later
Your help is greatly appreciated.
aanthony1
- StephenBDec 03, 2017Guru - Experienced User
If you are running XRAID, then you can do this. It should increase your storage by 1 TB (to 7 TB) when you replace the second disk. Upgrading disks 1 and 2 later on raise your volume size from 7 TB to 9 TB.
You do need to replace disk 4 first, since it has failed.
Sorry, just to confirm I have attached screen shots of my NAS 104.
I believe I can replace as it says XRAID on the right.
Is this correct? XRAID and RAID 5 is a version of XRAID?
Replace Disk 4 with new WD 3TB. Then Disk 3 with the same.
Thanks again.
