Obiwan_
Feb 09, 2012Apprentice
ReadyNAS 1100 Drive Update Questions
I have had my ReadyNas 1100 for about 6 mo. I bought it with 4ea 1TB drives. Updated it to the latest firmware 4.1.8 and now have run out of room. After refering to the compatability list I have purch...
mdgm-ntgr
Feb 09, 2012NETGEAR Employee Retired
Which WD20EARS (e.g. WD20EARS-00S8B1)?
Do you have a backup?
So you powered down the ReadyNAS, removed the 1TB disks and installed the three drives or did you replace one disk at a time?
If the former, try a factory default (wipes all data, settings, everything: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)
- Sep 29, 2022Retired_Member
