heatproofsean
Nov 13, 2019Aspirant
ReadyNas 1100 not accessible via VPN
In a domain environment, we have a ReadyNas 1100 and some Window 2003 Servers acting as File Servers. Users on our network can access both without problems. However those that connect via VPN ( managed by watchguard firewall) cannot access the ReadyNas drives or web interface (but can ping it).
VPN IP Pool is 10.181.20-80
DHCP Pool is 10.181.10.20-200
ReadyNas IP is 10.181.2.1 and 10.181.2.2 (Eth0 & Eth1)
Any help would be greatly appreicated as this is an on-going issue that I'm struggling with.
- heatproofseanAspirant
Just to add, I've tried mapping to the shares via Sharename (CHDNAS001) and IP. The latter just times out. Using IP prompts for a username/password which never works (NAS Admin nor their Windows account (User/admin/network admin all get the same result), as it just says "The specified network password is not correct".
Mapping via IP works when connected to the network
- SandsharkSensei
I suspect it's an SMBv1 issue, as that's all OS4.2.x supports. Your configuration sounds more complex than the usual solution of enabling SMBv1 in Windows10.
We do have SMBv1 enabled on every machine as our other file server is Windows 2003. And it does work when on the network but not over VPN.
