jacquesvanzijl's avatar
Aug 04, 2011
ReadyNAS 1500 and Seagate 3TB - Corrupt Root
Hi Guys
We have a Ready NAS 1500 RNRX400E with 4 x Seagate ST33000650NS " which is on the compatibility list "
im getting Corrupt root in my RAIDar panel, I have version 4.2.17 installed to.
Please could someone help me here
Thank you
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Did you just install these disks? If so did you use the disks before putting them in the ReadyNAS?
    Did you install all the disks at once?
    Is your data backed up?
  • ok got the problem,, was not memory, one harddrive failed, we did a seagate tool test and it failed.
    so format all the drives in a PC and re-installed it .... 100%
    thank you
  • ok we are back to where we started with - CORRUPT ROOT..!!!
    the device boot up with corrupt root, if i install a 1TB or 2TB constellation drive it works but as soon if i install the 3TB
    the system goes corrupt root..
    please any idea's
    mdgm-ntgr
    Have you checked the 3TB drive using SeaTools?
    When you checked the drives before did you run both short and long tests?
    Have you run the memory test?
  • Hello,
    I am having exactly the same problem with 3 new Seagate 3TB ST3000DM001 disks, which are also on the HCL...
    Did you find any solution on your problem??
ProSupport for Business
