jwilkens
Oct 14, 2017Aspirant
ReadyNAS 204 Ethernet Ports nor working
Good day, I need some help, I have a ReadyNAS 204 which has been working perfectly since I bought it about a year ago, but after struggling to connect to it I found that none of the lights on eit...
Sandshark
Oct 14, 2017Sensei
There is no way other than the ethernet connection to access the data. There are ways to recover the data from the drives using a PC and a Linux LIve CD. But unless you are not the original purchaser, your unit is still under warranty, so why mess with it?
jwilkens
Thank you,
I am the original purchaser and will return it, but I urgently need to access the data and can't wait for the replacement or repair to be done.
- StephenBOct 15, 2017Guru - Experienced User
Are you comfortable with Linux shell commands?
- jwilkensOct 15, 2017Aspirant
Good day,
Yes I am.
- StephenBOct 16, 2017Guru - Experienced User
Then if you connect all the drives to a PC, and boot that PC up with a linux Live boot disk, you can access the data.
You'll need to install mdadm and btrfs onto the linux system (if they are not preinstalled).
