jwilkens
Oct 14, 2017Aspirant
ReadyNAS 204 Ethernet Ports nor working
Good day, I need some help, I have a ReadyNAS 204 which has been working perfectly since I bought it about a year ago, but after struggling to connect to it I found that none of the lights on eit...
jwilkens
Thank you,
I am the original purchaser and will return it, but I urgently need to access the data and can't wait for the replacement or repair to be done.
Oct 15, 2017Guru - Experienced User
Are you comfortable with Linux shell commands?
- jwilkensOct 15, 2017Aspirant
Good day,
Yes I am.
- StephenBOct 16, 2017Guru - Experienced User
Then if you connect all the drives to a PC, and boot that PC up with a linux Live boot disk, you can access the data.
You'll need to install mdadm and btrfs onto the linux system (if they are not preinstalled).
- SandsharkOct 17, 2017Sensei
And especially since access to your data is so important, you clearly need to consider a backup plan once the NAS is replaced under warranty.
