Kardano
Mar 21, 2018Luminary
Readynas 204 n o admin page
RN204, FW 6.9.3
After installing app (phpsysadmin) from no web admin interface.
Tried restart, no help.
On ssh i get:
root@PMNAS01:~# systemctl status apache2
â apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2018-03-21 14:39:46 CET; 16min ago
Process: 7157 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=203/EXEC)
Process: 7057 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
Mar 21 14:39:45 PMNAS01 systemd[1]: Starting The Apache HTTP Server...
Mar 21 14:39:45 PMNAS01 fvapps[7057]: WARNING: Excluding bad https config for app 'nastools-netdata'
Mar 21 14:39:45 PMNAS01 fvapps[7057]: WARNING: Excluding bad https config for app 'smbplus'
Mar 21 14:39:46 PMNAS01 systemd[1]: apache2.service: Control process exited, code=exited status=203
Mar 21 14:39:46 PMNAS01 systemd[1]: Failed to start The Apache HTTP Server.
Mar 21 14:39:46 PMNAS01 systemd[1]: apache2.service: Unit entered failed state.
Mar 21 14:39:46 PMNAS01 systemd[1]: apache2.service: Triggering OnFailure= dependencies.
Mar 21 14:39:46 PMNAS01 systemd[1]: apache2.service: Failed with result 'exit-code'.
root@PMNAS01:~#
I can access data in shares, but no admin page.
I cannot download logs with RaiDar get Not a valid User Name or Password. (i know that name and pasword are OK)
Unit is in Remote support mode.
Can someone help me with this problem? I do not want to facroty default my unit...
mdgm-ntgrplease help (help me Obiwan Kenobi you're my only hope)
Thanks.
Hi Kardano
Great! hope everything's okay now.
Hope you can use the accepted solution button once you have finished testing.
Regards!
