jarness17's avatar
jarness17
ReadyNas 2120 Syncing
Hi,
We have a ReadyNas 2120 which twice over the last two months has randomly started running a sync and stating "The ReadyNas is currently syncing. During this process, the system is still accessible, however, performance and Admin Page responisveness might be impacted".
The logs state:
Wed Feb 19 2020 6:26:41 System: ReadyNASOS background service started.
Wed Feb 19 2020 6:26:38 Volume: Resyncing started for Volume UserNAS_RAID6Volume.
Wed Feb 19 2020 6:26:36 System: ReadyNASOS service or process was restarted.
Wed Feb 19 2020 6:24:35 System: ReadyNASOS background service started.
Wed Feb 19 2020 6:24:30 Volume: Resyncing started for Volume UserNAS_RAID6Volume.
Wed Feb 19 2020 6:24:28 System: ReadyNASOS service or process was restarted.
Does anyone know why this would randomly start? I always assumed this was just when hotswapping disks and the RAID rebuilds but we havent changed any disks.
Its causing us a lot of issues as the devices goes very slow.
I've also attached the error.
Thanks for your help
Jacob
  • StephenB's avatar
    Why did the above restart happen? Perhaps look at the full log zip file.
    I believe that is what is triggering the resync.
    • Sandshark's avatar
      Sandshark
      Sensei
      One common reason is a drive error (often ATA error) that makes the NAS drop the drive from the array, then later pick it up as good and start the re-sync.  I just replaced a drive for that exact same issue -- SMART shows 300+ ATA errors.
ProSupport for Business
