gufau
Apr 06, 2016Aspirant
Readynas 2120 V2
Hello to all, I am interested in this model for private use. I would like to know beforehand if the memory is "upgradable" I would like to know if it is compatible pro w10 finally if there is a...
- Apr 20, 2016
Hello gufau,
You are most welcome!
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Regards,
gufau
Thanks for your answer,
Yes, I made a mistake of reference, it is the RN2120 V2 http://www.netgear.fr/business/products/storage/readynas/RN2120.aspx#tab-techspecs
Guy
JennC
Apr 06, 2016NETGEAR Employee Retired
Hello gufau,
Thanks for correcting the model. Only ReadyNAS 312, 314, 316, 516 and 716 are compatible with expansion chassis. As for the memory upgrade, please visit ReadyNAS Memory Compatibility List article for inquiry about memory upgrade. Some community members also share their experiences, perhaps wait for others to respond.
