CABird_UK
Jul 22, 2023Tutor
ReadyNAS 214 - Plex poster & background images
I wish to move Plex media files plus the linked poster & background images to another NAS. I have implemented the Solved: Re: Accessing Plex Media Server Library Files - NETGEAR Communities Howe...
- Jul 22, 2023
I have implemented the Solved: Re: Accessing Plex Media Server Library Files - NETGEAR Communities However the assigned poster and background image links, are not present. I have hundreds of media tiles. The thought of having to manually, redo all the links is less welcome.
Is there a method to install Pleex media to a new NAS with the image links?
That can be tricky. Plex offers some guidance here:
FWIW, a few months ago I did this when moving Plex from one Windows PC to another. It didn't seem to quite work, so I eventually did rescan the media libraries, and manually fixed up media that was mismatched (and maybe adjusted some cover art).
michaelkenward
Jul 22, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
With an NAS device, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
