CABird_UK
Jul 22, 2023Tutor
ReadyNAS 214 - Plex poster & background images
I wish to move Plex media files plus the linked poster & background images to another NAS. I have implemented the Solved: Re: Accessing Plex Media Server Library Files - NETGEAR Communities Howe...
- Jul 22, 2023
I have implemented the Solved: Re: Accessing Plex Media Server Library Files - NETGEAR Communities However the assigned poster and background image links, are not present. I have hundreds of media tiles. The thought of having to manually, redo all the links is less welcome.
Is there a method to install Pleex media to a new NAS with the image links?
That can be tricky. Plex offers some guidance here:
FWIW, a few months ago I did this when moving Plex from one Windows PC to another. It didn't seem to quite work, so I eventually did rescan the media libraries, and manually fixed up media that was mismatched (and maybe adjusted some cover art).
CABird_UK
Jul 22, 2023Tutor
Sadly there appears to be no way to submit a question for Netgear NAS 214.
Please advise. Thank you.
michaelkenward
Jul 22, 2023Guru - Experienced User
What does that mean?
It might helped if you found the right model number. There is no "Netgear NAS 214".
Look at the label on the thing.
- CABird_UKJul 22, 2023Tutor
My Netgear ReadyNAS is definitely 214.
RN214 | Product | Support | NETGEAR
Please see attached image.
I can access the Plex files and copy them to another NAS drive.
The problem is the background and poster images are not attached to the Plex media (mp4) file. Clearly, I have missed a file or the correct procedure to add the files to the new Netgear ReadyNAS 214.
Thank you for any help you can provide.
- michaelkenwardJul 22, 2023Guru - Experienced User
The model number is RN214. It is not "ReadyNAS 214". Sadly, these computer things are unforgiving when fed inaccurate data.
So, ask for help with the RN214 in the right place.
ReadyNAS Cloud Storage - NETGEAR Communities
Narrow it down with:
Search - NETGEAR Communities – RN214
Search - NETGEAR Communities – RN214 Plex
As responses so far show, there really isn't much that most router users can bring to the party.
