CABird_UK
Jul 22, 2023Tutor
ReadyNAS 214 - Plex poster & background images
I wish to move Plex media files plus the linked poster & background images to another NAS. I have implemented the Solved: Re: Accessing Plex Media Server Library Files - NETGEAR Communities Howe...
- Jul 22, 2023
I have implemented the Solved: Re: Accessing Plex Media Server Library Files - NETGEAR Communities However the assigned poster and background image links, are not present. I have hundreds of media tiles. The thought of having to manually, redo all the links is less welcome.
Is there a method to install Pleex media to a new NAS with the image links?
That can be tricky. Plex offers some guidance here:
FWIW, a few months ago I did this when moving Plex from one Windows PC to another. It didn't seem to quite work, so I eventually did rescan the media libraries, and manually fixed up media that was mismatched (and maybe adjusted some cover art).
Jul 22, 2023Guru - Experienced User
CABird_UK
Jul 23, 2023Tutor
I have had to manually add the poster, and background image links.
Thank you.
