Eckers
Oct 18, 2021Guide
ReadyNas 214 Freezes on Start-up
Hello, My ReadyNas became unresponsive so i had to unplug it to get it started again. However, on restart it has frozen at 88% and the display window says "fvbackup-q.servi". I've attached a phot...
- Oct 19, 2021
What did you do at the reset menu after you used the reset button? If you did a factory default from there, you destroyed your data.
Sandshark
Oct 19, 2021Sensei
- EckersOct 19, 2021Guide
I didn't get the option of a Factory Default. The Readynas restarted and booted up but no data was there. So i replaced the ethernet cables and started the system again and this is where the system is hanging on the 88% complete screen.
- EckersOct 21, 2021Guide
thank you your message reminded me of the Reboot menu. i was able to reinstall the operating system and this resolved the issue i was having.
- Jan 17, 2024Retired_Member
