JayV_84
Dec 17, 2019Aspirant
ReadyNAS 214 Read Only
Dear Netgear, Since yesterday morning my ReadyNAS 214 says all the files and documents are read-only. I have started a disk check and it doesn't come up with any errors. Also it shows all the d...
- Dec 18, 2019
Hi JayV_84,
I found these file system errors on the logs:
[Tue Dec 17 17:39:03 2019] BTRFS error (device md126): parent transid verify failed on 87273472 wanted 4831286 found 4828229
[Tue Dec 17 17:40:03 2019] BTRFS error (device md126): parent transid verify failed on 87273472 wanted 4831286 found 4828229
[Tue Dec 17 17:41:03 2019] BTRFS error (device md126): parent transid verify failed on 87273472 wanted 4831286 found 4828229You can try contacting NETGEAR support and see if they can still do some corrective changes via backend access. Otherwise, it will be best for you to backup your data, then restore the NAS from factory default.
JayV_84
ReadyNAS firmware is 6.10.2 and i have 4 Western Digital 4TB disk installed.
I've tried rebooting via webinterface, turning off and on but nothing has helped so far..
