JayV_84
Dec 17, 2019Aspirant
ReadyNAS 214 Read Only
Dear Netgear, Since yesterday morning my ReadyNAS 214 says all the files and documents are read-only. I have started a disk check and it doesn't come up with any errors. Also it shows all the d...
- Dec 18, 2019
Hi JayV_84,
I found these file system errors on the logs:
[Tue Dec 17 17:39:03 2019] BTRFS error (device md126): parent transid verify failed on 87273472 wanted 4831286 found 4828229
[Tue Dec 17 17:40:03 2019] BTRFS error (device md126): parent transid verify failed on 87273472 wanted 4831286 found 4828229
[Tue Dec 17 17:41:03 2019] BTRFS error (device md126): parent transid verify failed on 87273472 wanted 4831286 found 4828229You can try contacting NETGEAR support and see if they can still do some corrective changes via backend access. Otherwise, it will be best for you to backup your data, then restore the NAS from factory default.
JohnCM_S
Dec 17, 2019NETGEAR Employee Retired
Hi JayV_84,
Welcome to the Community!
The NAS might have detected a file system problem which caused the volume to become read-only. It will be best if you back up your data as soon as possible while you can still access it.
You may download the NAS system logs then provide it to us so we can check the exact cause. You may upload it to a file-sharing site then send to me the download link via PM (private message).
- JayV_84Dec 17, 2019Aspirant
Hi John,
Thanks for your quick reply!
When i try to download the log files it gives me the follow message :
Forbidden
You don't have permission to access /dbbroker on this server.
I am logged in as Admin
I have just send the link to the log file
It seems Safari was the problem why i couldn't get the logs to download, so i tried Chrome and that worked.
Thanks in advance!
- JohnCM_SDec 18, 2019NETGEAR Employee Retired
Hi JayV_84,
