Bencool
Oct 12, 2023Aspirant
ReadyNAS 214 volume is set to Read Only, please help.
My ReadyNAS 214 suddenly set to Read Only, And when I go to the logs, it just said "Volume: The volume data encountered an error and was made read-only. It is recommended to backup your data." I h...
Oct 12, 2023Guru - Experienced User
Bencool wrote:
I have run the "Scrub" and "Disk Test" in the volume setting windows. However, it did not show any errors.
Back up the data, as it is at risk. Don't reboot the NAS until after you've done that - it is likely that the volume will fail to mount if you reboot.
Then we can help pursue troubleshooting.
I redacted your log link, as there is some privacy leakage - best to provide them via private message (PM) using the envelope icon in the upper right of the forum page.
I did download the log zip, and will take a look when I have a few minutes.
Some of the logs have rotated, but I also am not seeing any disk issues on the data volume. I am seeing issues with the btrfs metadata being corrupted.
Oct 07 00:15:20 bliao-readynas kernel: BTRFS error (device md127): cleaner transaction attach returned -30
Oct 07 00:29:35 bliao-readynas kernel: BTRFS error (device md127): parent transid verify failed on 23853767229440 wanted 2956556 found 4714624
Oct 07 00:29:35 bliao-readynas kernel: BTRFS warning (device md127): Skipping commit of aborted transaction.
Oct 07 00:29:35 bliao-readynas kernel: BTRFS: error (device md127) in cleanup_transaction:1864: errno=-5 IO failure
Oct 07 00:29:35 bliao-readynas kernel: BTRFS info (device md127): forced readonly
Oct 12 09:59:28 bliao-readynas kernel: BTRFS error (device md127): cleaner transaction attach returned -30
Oct 12 10:07:21 bliao-readynas kernel: BTRFS error (device md127): parent transid verify failed on 88637440 wanted 4714626 found 4714625
There are a lot of other transid verify errors, but most are duplicative (identical).
Best option here is to back up the data and then do a factory default. After that, reconfigure the NAS, restore the data, reinstall apps. While this is a lot of work, it ensures that you get a clean file system.
Since most of the errors are identical, it might be possible to repair. But this is risky, so making a full backup first is important.
Although I am not seeing errors on the data volume drives, I am seeing errors on two usb drives:
Oct 06 22:17:38 bliao-readynas kernel: blk_update_request: I/O error, dev sdf, sector 15099759872
Oct 07 00:29:46 bliao-readynas kernel: EXT4-fs (sdf1): warning: mounting fs with errors, running e2fsck is recommended
Oct 07 00:34:47 bliao-readynas kernel: EXT4-fs (sdf1): error count since last fsck: 824
Oct 07 00:34:47 bliao-readynas kernel: EXT4-fs (sdf1): initial error at time 1438131903: ext4_lookup:1051: inode 151724033
Oct 07 00:34:47 bliao-readynas kernel: EXT4-fs (sdf1): last error at time 1691675655: ext4_mb_generate_buddy:759
Oct 07 13:10:03 bliao-readynas kernel: EXT4-fs error (device sdf1): ext4_mb_generate_buddy:759: group 37096, block bitmap and bg descriptor inconsistent: 1574 vs 1576 free clusters
Oct 07 13:10:03 bliao-readynas kernel: JBD2: Spotted dirty metadata buffer (dev = sdf1, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
and
Oct 12 10:09:52 bliao-readynas kernel: EXT4-fs (sdc1): error count since last fsck: 825
Oct 12 10:09:52 bliao-readynas kernel: EXT4-fs (sdc1): initial error at time 1438131903: ext4_lookup:1051: inode 151724033
Oct 12 10:09:52 bliao-readynas kernel: EXT4-fs (sdc1): last error at time 1696695003: ext4_mb_generate_buddy:759
It's possible this is the same drive (with a different drive letter).
Finally, the OS partiton appears to be fuller than usual. Not yet dangerous, but still something to take a look at after the main issues are resolved.
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
/dev/md0 3.7G 2.0G 1.6G 57% /
Normally the OS is about 25% full.
