Bencool
Oct 12, 2023Aspirant
ReadyNAS 214 volume is set to Read Only, please help.
My ReadyNAS 214 suddenly set to Read Only, And when I go to the logs, it just said "Volume: The volume data encountered an error and was made read-only. It is recommended to backup your data." I h...
Oct 14, 2023Guru - Experienced User
Jackvd wrote:
Making data backups was/ is not possible, because the system has to wright something to a readonly disk... 🙂
Not the case. You can back up the data from a read-only volume. That can either be done from ReadyNAS backup jobs, or by copying the files with other tools (one of several examples is freefilesync running on a PC). The backup job config files are in the OS partition (not on the data volume), and that should still be writable.
Your data is definitely at risk, so backing up the data ASAP is really important. Rebooting the NAS often results in the volume not mounting at all. Even if you are really careful not to shut it down or reboot, all it takes is a power glitch to force a reboot. Also, a corrupted file system can trigger a crash.
Jackvd wrote:I can share my logs if that is any help.
PS. I just looked at the system and kernel logs and they are filled with error's.... It doesn't mean anything to me, but perhaps it gives a clue to an expert 🙂
I am willing to take a look. Put the full zip in cloud storage (dropbox, etc), and send me a private message (PM) with a download link. Send the PM using the envelope icon in the upper right of the forum page. Make sure the permissions are set so anyone with the link can download.
In most cases I will recommend a factory reset, as this is the best way to make sure you have a fully clean file system.
Jackvd
Oct 14, 2023Apprentice
Hi StephenB,
Thx for replying so quickly.
I made a copy of the changed files to a Folder on my Mac, so that together with my backups will do.
But the Backup tool on the ReadyNAS is not working... The Backup tool does not see my attached USB backup drive. The external drive does show up as a volume, but does not show up in the tool.
I will put a link to the log-zip in a message.
I am pretty sure what the recommendation will be, but I can always hope 🙂
I am just curious on what the issue is.
