Bencool
Oct 12, 2023Aspirant
ReadyNAS 214 volume is set to Read Only, please help.
My ReadyNAS 214 suddenly set to Read Only, And when I go to the logs, it just said "Volume: The volume data encountered an error and was made read-only. It is recommended to backup your data." I h...
Jackvd
Oct 14, 2023Apprentice
Hi,
Funny enough I have the same problem....
It started around september 3.
After fooling around with my TimeMachine space in the evening, the next morning I got the 'volume data01 encountered an error and was made readonly.' error next morning.
The system also triggered a daily message that a USB device was connected. This normally doesn't happen, but since then it does everyday (like a service is started everyday).
I looked through the disklogs but didn't find any error's. Nothing on the disks either.
Making data backups was/ is not possible, because the system has to wright something to a readonly disk... 🙂
A reboot made no difference and a reinstall of the OS either.
I also performed a extensive disk test from the boot-menu.
Now, I am not eager to do a complete new setup and restore, since the system does not make a backup of the system itself (which I always found strange....) and it needs lots of manual configuration (like folders and so on).
But if that's what it takes, I will bite the bullet 🙂
I can share my logs if that is any help.
The system is a RN214 with 4 x 3TB - Seagate ST3000VN007
OS: 6.10.8
PS. I just looked at the system and kernel logs and they are filled with error's.... It doesn't mean anything to me, but perhaps it gives a clue to an expert 🙂
Thx!
Jack
Bencool
Oct 16, 2023Aspirant
Jackvd It seems I have exactly the same problem as you. I also do some TimeMachine space updating or deleting. After that, the data volumn is locked.
If you could fix the problem instead of restoring the NAS, please let me know.
- JackvdOct 16, 2023Apprentice
StephenB did look at my logs, but he couldn't find the root cause because the data didn't go back far enough.
That was probably my fault since I did perform a reinstall of the OS from the Bootmenu.
The other thing that didn't help is that my volume is encrypted and StephenB explained to me that he never had a setup like that.
Anyway; the logs showed massive checksum errors while writing so somehow the OS had a hick-up.
So I did a factory reset and reinstalled the complete system....
I did it before a couple of years ago after two of my disks got corrupt in my Raid5 setup 😞
I have backups of all my data and the system restored 2.7TB up until now. Probably another two days for it to complete.
Maybe your issue is different and if you have the complete logs, StephenB can have a look at them.
If you have to do a factory reset, make sure you follow the right sequence. There are instructions in the community that you can follow.
Sorry I couldn't help and good luck!
PS. it is weird though, that your problem sounds just like mine.....
