bastelspezi
Jun 03, 2016Aspirant
READYNAS 214 wont show smart values
hey guys is there any knows issue with a READYNAS214 and a seagate NAS drive 6TB model st6000vn0021. cuz my nas wont show its smart values ever since I've inserted it nor does it show the correct tem...
JennC
Jun 04, 2016NETGEAR Employee Retired
Hello bastelspezi,
Before getting a disk for your ReadyNAS, please always check HCL first.
Welcome to the community!
- StephenBJun 06, 2016Guru - Experienced User
Good Grief. The st6000vn0001 is on the list, but the st6000vn0021 is the currently shipping model. Are you serious?
- LaserbaitOct 23, 2016Luminary
Hello StephenB,
So is that how it works in th HCL for Seagate? If the ST6000VN0001 is on the HCL, then all ST6000VN00X1's are, or, should be supported?
Thanks!
- StephenBOct 23, 2016Guru - Experienced User
Laserbait wrote:
So is that how it works in th HCL for Seagate? If the ST6000VN0001 is on the HCL, then all ST6000VN00X1's are, or, should be supported?I don't work for Netgear, and I'm not sure how strictly they interpret the HCL these days. A while back JennC posted something about Netgear going to a "drives what won't work" approach, but I haven't seen anything about that since.
Personally I'd find it extremely annoying if Netgear denied support for any ReadyNAS because it was using a Seagate IronWolf or Nearline NAS, or a WD Red or WD Red Pro.
