spanky762
Jun 04, 2018Aspirant
ReadyNAS 2304 - Volume Data is Syncing Cannot Set RAID 10
OK, first things first, the Model I selected for this post is incorrect. I could not select the ReadyNAS 2304 Diskless - which is what I have.
Scenario: BRAND NEW ReadyNAS 2304, installed 4 NE...
- Jun 04, 2018
1. After disabling X-RAID you can destroy the default volume and create the one you want.
2. You can destroy the default volume. Destroying a volume will wipe all the data on it.
3. This is normal. The disks have to be synced sector by sector to setup the RAID and the RAID is at a lower level than the filesystem.
mdgm-ntgr
Jun 04, 2018NETGEAR Employee Retired
spanky762
Thanks for such a quick response!
So, just to be sure I understand correctly, I need to wait for the resync to complete, and then once it is completed I can destroy the RAID-5 and create the RAID-10?
