spanky762's avatar
spanky762
ReadyNAS 2304 - Volume Data is Syncing Cannot Set RAID 10
OK, first things first, the Model I selected for this post is incorrect.  I could not select the ReadyNAS 2304 Diskless - which is what I have.   Scenario: BRAND NEW ReadyNAS 2304, installed 4 NE...
  • mdgm-ntgr's avatar
    Jun 04, 2018
    1. After disabling X-RAID you can destroy the default volume and create the one you want.
    2. You can destroy the default volume. Destroying a volume will wipe all the data on it.
    3. This is normal. The disks have to be synced sector by sector to setup the RAID and the RAID is at a lower level than the filesystem.
ProSupport for Business
