User2032
Feb 27, 2024Aspirant
ReadyNAS 3100: VBAT power is out of normal range
Hi all!
I have a ReadyNAS 3100 that started logging the following error:
VBAT power is out of normal range [expected: 3.30 current: 2.94].
Assuming the error was referring to the CMOS battery, I replaced the CR2032 lithium coin cell on the motherboard with a known good battery, and it's still complaining about the VBAT voltage.
Is there another 3.3-V battery somewhere that needs to be replaced?
Thanks in advance for any help!
M
- SandsharkSensei
That's odd, because I don't see any reference to VBAT in /etc/frontview/sensors/RN3100.conf. Have you been independently doing something with lmsensors?
- User2032Aspirant
Hi Sandshark,
I inherited management of this device, and I assume it's bone stock. Having written that, is there a way to enable SSH so I can poke around and see what I have in /etc/frontview/sensors/RN3100.conf?
Thanks for your help!
M
- User2032Aspirant
Here's all the voltage-related stuff from boot_info.log:
labelvol0: VCORA
minvol0: 0.92
maxvol0: 1.38
labelvol1: VCORB
minvol1: 1.12
maxvol1: 1.38
labelvol2: VVTT
minvol2: 1.00
maxvol2: 1.38
labelvol3: V-12
minvol3: 10.73
maxvol3: 13.25
labelvol4: VDIM
minvol4: 1.62
maxvol4: 1.98
labelvol5: V3_3
minvol5: 2.96
maxvol5: 3.63
labelvol6: V+12
minvol6: 10.75
maxvol6: 13.25
labelvol7: V5_0
minvol7: 4.49
maxvol7: 5.50
labelvol8: V5SB
minvol8: 4.49
maxvol8: 5.50
labelvol9: VBAT
minvol9: 2.96
maxvol9: 3.63- SandsharkSensei
On the Settings page, just click on SSH to enable it. You then log in as user root using the NAS admin password.
That said, boot_info.log does not contain that type of info on my various ReadyNAS, so I believe your predecessor has done some significant tweaking of the OS. In order to do so, SSH would have to have been enabled. So if the SSH button has a green bar on the Settings page, it's already enabled.
