mikebomb
Oct 22, 2023Aspirant
ReadyNas 312 - External storage device is connected but the file system is not recognized
RN312, 6.10.9. I recently got a new 18 TB external USB drive, formatted NTFS. When I first connected it, it was recognized without issue. I started copying data from the existing USB drive to the...
mikebomb
Oct 29, 2023Aspirant
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 753M 2.9G 21% /
tmpfs 993M 0 993M 0% /dev/shm
tmpfs 993M 3.8M 989M 1% /run
tmpfs 497M 4.1M 493M 1% /run/lock
tmpfs 993M 0 993M 0% /sys/fs/cgroup
/dev/md127 9.1T 5.4T 3.8T 59% /data
/dev/md127 9.1T 5.4T 3.8T 59% /home
/dev/md127 9.1T 5.4T 3.8T 59% /apps
/dev/sdd1 11T 9.9T 1.1T 91% /media/USB_HDD_4
/dev/sdc2 17T 362M 17T 1% /media/USB_HDD_11
=== df -i ===
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 253417 420 252997 1% /dev
/dev/md0 0 0 0 - /
tmpfs 254087 1 254086 1% /dev/shm
tmpfs 254087 548 253539 1% /run
tmpfs 254087 28 254059 1% /run/lock
tmpfs 254087 15 254072 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data
/dev/md127 0 0 0 - /home
/dev/md127 0 0 0 - /apps
/dev/sdd1 0 0 0 - /media/USB_HDD_4
/dev/sdc2 0 0 0 - /media/USB_HDD_11As you can see, /dev/md0 is only 21% used and the new drive is mounted to /dev/sdc2 (although the drive is currently off).
I've tried to reply to this post multiple times. Each time my reply looks like it's been accepted and then it disappears.
