mikebomb
Oct 22, 2023Aspirant
ReadyNas 312 - External storage device is connected but the file system is not recognized
RN312, 6.10.9. I recently got a new 18 TB external USB drive, formatted NTFS. When I first connected it, it was recognized without issue. I started copying data from the existing USB drive to the...
mikebomb
Oct 30, 2023Aspirant
Well, a reply of mine has finally gone through. I'll try to put the data here again.
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 753M 2.9G 21% /
tmpfs 993M 0 993M 0% /dev/shm
tmpfs 993M 3.8M 989M 1% /run
tmpfs 497M 4.1M 493M 1% /run/lock
tmpfs 993M 0 993M 0% /sys/fs/cgroup
/dev/md127 9.1T 5.4T 3.8T 59% /data
/dev/md127 9.1T 5.4T 3.8T 59% /home
/dev/md127 9.1T 5.4T 3.8T 59% /apps
/dev/sdd1 11T 9.9T 1.1T 91% /media/USB_HDD_4
/dev/sdc2 17T 362M 17T 1% /media/USB_HDD_11As you can see, /dev/md0 is only 21% used, and the new drive is at /dev/sdc2, although how it knows the status of the drive when it's turned off is beyond me.
Any other suggestions?
